4020 frame rails
Jason Z in MO
04-15-2006 19:45:40
I'm trying to remove a broken bolt in the frame rail on a 4020. I'm using left handed bits and drilled an 1/8" hole in the center. Thinking I would be smart... I took a small torch and heated in the hole. It was never red but somehow I hardened it and the drill bits won't even scratch it!
How do I remove the temper?
Thanks and happy Easter!
Jason
JDBert
04-17-2006 06:54:01
 Re: 4020 frame rails in reply to Jason Z in MO, 04-15-2006 19:45:40
I just dug one out of my 4020, I got lucky though and used a center punch and just turned it out. Never have had one that was tight in the hole after the head broke off, all the ones I've ever had to dig out I did this way.
JimKS
04-16-2006 13:59:20
I've had lots of people tell me to try wax- it's never worked for me.
A masonry bit works surprisingly well for this sort of thing. I worked on a 4440 a while back where several of the bolt holes in the engine block were wallowed out too big even to repair with a 3/4" helicoil. We had the local welder come out and weld them up... and unbeknownst to us, he used a new type of nickel rod that he hadn't tried before. The welded-in metal was so hard that nothing in the shop would touch it. It'd dull a snap-on cobalt bit (or even a center-punch) right away. He sent some masonry bits over to the shop, and they cut through. It wasn't real easy, but they worked.
Here's another idea, but you'll only want to try this if you have the frame off. I've had real good luck removing broken bolts with a mig welder. You take a nut the same size as the bolt, and weld it to the broke bolt through the hole. A stick welder might work, but I always use a mig so I don't have to bother with slag. The weld won't stick to the cast anyway, so that's no problem as long as you're careful. I've had good luck doing it this way if I drill a hole in the bolt first so that there's a bit of a corner on the bolt to melt into.
JD man in SD
04-16-2006 04:55:11
be very carefull with torch later JD case iron is aloyed and will blow out with torch been there done that
Kent
Mike M
04-16-2006 03:41:39
I don't know about removeing that temper ,but you can buy carbide tipped masonary bits fairly cheap and they may cut through it. If all else fails get that torch back out heat it up and heat the oxygen and it will blow out. The cast iron doesn't cut so good and may not get too damaged. I wouldn't use an easy out unless you know it is loose in the hole otherwise then the esay out will break.
Jason Z in MO
04-16-2006 07:50:26
 Re: 4020 frame rails in reply to Mike M, 04-16-2006 03:41:39
Thanks for the tips! I think the bolt is fairly loose but I only have an 1/8" hole and the bolt is 1/2" maybe 5/8" probably break the easyout... I have melted the bolts out of the cast iron wheels before; worked great too. Problem here is it's a blind hole and no place for the slag to go except back at the torch.
I think I have a couple of masonary bits, I'll give it a try!
Thought about getting it hot again and drilling with the temp high.
JMS/MN
04-16-2006 10:18:10
 Re: 4020 frame rails in reply to Jason Z in MO, 04-16-2006 07:50:26
Ever apply wax to the bolt as it cools after heating?
