4630 pitman arm
fullobull
04-15-2006 19:02:02
need to no if i am doing something wrong? I am trying to get the pitman arm off my 4630 the seal is down in the steering box. I have used a puller and heated it some and no luck. any body got any suggestions.
superfarmer
04-15-2006 19:42:59
 Re: 4630 pitman arm in reply to fullobull, 04-15-2006 19:02:02
The only way I"ve ever got those things off is to remove the 4 bolts that hold the seal/bearing flange on and carefully pull the whole unit out. Whatever you do, don"t turn the steering wheel with the arm and gear out, it can get ugly if there"s a feedback piston involved. Next, find a piece of about 6" heavy wall pipe and set the unit on, and drive the shaft out with a big sledge. When you hear it pop out, you"ll see how futile a puller is. It"s a tapered spline, so heat won"t necessarily help, unless it"s really rusted like the one on my 80 was.....
Dave
fullobull
04-16-2006 06:09:24
 Re: 4630 pitman arm in reply to superfarmer, 04-15-2006 19:42:59
thanks for the input. I wasnt sure what I would get into if I removed the 4 bolts or if it would even come apart that way. but gonna give it a try.
JimKS
04-16-2006 13:51:21
 Re: 4630 pitman arm in reply to fullobull, 04-16-2006 06:09:24
I"ve removed lots of them just by beating on them. I have a cutoff piece of a hydraulic cylinder rod that I use- it"s about 1 1/4" in diameter and about 2 1/2 feet long. I set it on the front axle with one end up against the steering arm, and I hit the other end real hard with a 9 lb sledge. After two or three hits it"s usually loose. I"ve never run into one yet that I couldn"t remove (only been working on Deere"s for three years though). Some of the guys at the shop have said that sometimes they"re stuck real good, and you have to heat them with a torch before beating on them.
But if you can"t get it off the shaft, I guess you could pull it out with the shaft like this other feller said- that should work fine. Make sure and mark the position of everything so you don"t get it back together one tooth off.
