Joe, when youy say "pulled needle out" Im guessing you mean you unscrewed and out the carbs top needle adjuster(s) right????? If gas dont run out the carbs bottom drain cock plug but you indeed have fuel entering the carb (remove line and turn on gas and it ought to flow freely the size of lines ID), the problems NOT the float is stuck at the bottom (bowl could flood over), although it could be stuck at the top n not letting the needle valve drop down to let gas in through the hole in the seat??? My guesses are its: 1) Gun n varnish have the needle stuck up into the seat and shes not dropping down to let gas in. Tapping n shock n gumout may cure that !!!! 2) Theres dirt or rust or crud stuck in the seat and even if the float dropped and the needle dropped down, no gas can get thru the seat opening. 3) The carbs side strainer is all clogged up so gas isnt getting down into the needle n seat area at the bottom. 4) The float is stuck at the top n not dropping down to lower the needle down n out of the seat. Heres what I would do if youre sure the gas line has good gas flow into the carb: 1) Remove the carb side strainers lil side drain pipe plug and use gumout n air n spray n clean n flush it out then see if gas enters the bowl n runs out the bottom drain????? ? 2) If not, remove the side strainers lil top nut n cap (may need new gasket) and use gumout etc to clean n flush all that strainer area out. While in there spray n soak gumout at the bottom cuz thats where the needle n seat are and gum or varnish may get flushed away????? ? 3) If you still cant get gas to flow into and out the needle n seat area and into the bowl, you may have to pull the bowl and inspect the float n needle n seat etc and get it all cleaned up n working free to shut gas off as float rises. Make sure the floats not a leaker and raises the needle into the seat n shuts gas off at correct level. You may need a new needle valve n seat if she leaks after all this if the floats okay but a good gumout cleaning may well free up the needle n float assembly so gas runs into n out the side strainer and then throught the seat to fill the bowl AGAIN THIS ASSUMES GAS FLOWS TO THE CARB AT LEAST. Let us know Good Luck n God Bless Have a happy n blessed Easter John T
