50 B transmission noise
MDM
04-14-2006 20:38:43
Just got a 1950 B up and running, when using any of the gears on the right side of the quadrant (4th,2nd,1st, and reverse) I have a very distinct steady "clunk" when using any of the gears on the left side...i get no noise at all. Do I have a chipped tooth on a gear? If so, why is the noise in all gears on the right side? Any ideas????
2cylinderlp
04-14-2006 21:55:11
 Re: 50 B transmission noise in reply to MDM, 04-14-2006 20:38:43
There is a path through the gear train that is used when you are over on the right side, that is not used when you are over on the left side. As you loop the gear shift lever from side to side you are moving a a gear I think is called the shaft drive sliding gear. Think of it's function as sort of like high and low range. It allows getting two speeds out of other gears in the transmission. You might have a broken tooth in that gear. You don't hear it when your shift lever is over on the left because in that position, the shaft drive sliding gear is coupled directly to the transmission input shaft and there isn't any other gear running against it. Alternatively, the noise could be a broken tooth in the countershaft idler gear which is the gear that runs against the shaft drive sliding gear if I remember correctly. In this explanation, a picture really is worth a thousand words and a John Deere or IT manual for a "B" or a "50" would show very clearly what is going on there. Fortunately, I think the countershaft idler gear is available as a new part. I don't know about the other one.
