FIT on Phosphoric Ques
Henry M
04-14-2006 18:50:59
Frank
I notice you have referenced "spritzing" parts with acid after the electrolysis tank, cleaning and drying them.
I have not found a pump gun/bottle that will spray the stuff I get from Lowes. Are you diluting it someway so it will go thru one of those spray bottles that is found in the garden section.
Let me know pls, I am in the spritzing mood - using the brush is getting tiring.
F-I-T
04-14-2006 19:56:16
 Re: FIT on Phosphoric Ques in reply to Henry M, 04-14-2006 18:50:59
Henry:
The stuff I buy, like the Ph-Ospho-Ric+ at Lowe's, is only just a bit heavier than water, maybe like 50/50 antifreeze, and it squirts fine for me from a plant mister bottle. I have also sprayed it on with an old primer gun or a garden sprayer.
If you dilute it you might have it run off before it was completely finished.
Frank
Henry M
04-15-2006 05:34:37
 Re: FIT on Phosphoric Ques in reply to F-I-T, 04-14-2006 19:56:16
Thanks, I am going to lowes anc make sure I have the stuff you use. That is if I can refinance the home to put gas in the tank.
