Front wheels for 1941 B JD
R. G. Gill
04-14-2006 17:48:30
I have a 41 B J.D. It is a BW model with front end A1100R. The hubs are A1553R. I need to know what the correct front wheels are. Part#. I know that 1268's don't fit. Any help would really be apprecieated.
Thanks you R. G. Gill
Duane Larson
04-14-2006 19:19:32
 Re: Front wheels for 1941 B JD in reply to R. G. Gill, 04-14-2006 17:48:30
R.G. Gill,
Your BW came with either of two wheels. The third version of JD1232R, or JD1261R. Both are non-reversible (the JD1268R is reversible). Best as I can determine, the 1232 was used from early '40 to sometime between May and Dec 1941. So the 1261R started sometime between May and Dec 1941 and was used until 200999.
Both wheels have a 4.00Ex16" rim. The part number was not stamped in the original wheels, but I have seen replacement 1261 wheels stamped. They both have 4 slots between the rim and the wheel, with 6 mounting holes and 3 holes for front weights, for a total of 9 holes in the bolt ring. The difference between JD1232R(3) and JD1261R is the number of rivets attaching the rim to the center wheel. The JD1232R has two rivets/contact area (for a total of 8 rivets), while the JD1261R has 3 rivets/contact area (for a total of 12 rivets).
In my opinion, short of locating a decision record addressing the changeover, either wheel would be fine for your BW.
R. G. Gill
04-15-2006 11:48:50
 Re: Front wheels for 1941 B JD in reply to Duane Larson, 04-14-2006 19:19:32
Thank you Duane for the information. I am new at this and only know enough to be dangerous to myself.
Thanks again, I will use this info in my quest to find some wheels.
R. G. Gill
BMAN
04-14-2006 19:17:57
It looks like you would want a JD1275R which is a non reversible 16 inch rim
R. G. Gill
04-15-2006 11:50:39
 Re: Front wheels for 1941 B JD in reply to BMAN, 04-14-2006 19:17:57
Bman thanks for taking the time to reply. I will use this along with the other #'s that I recieved and maybe I will be able to find a set of wheels that will work.
Thanks
R.G.Gill
