1950 JD B and PCV 107622 power lift
MACE
04-14-2006 11:21:36
Howdy Fellers,
Question...
Hooked up to a sickle mower this morning and the 3 point hitch wont stay up. I assume it is leaking down. Soon as it goes to the top it leaks down in about 10 seconds. So I pulled the power lift assembly off the back of the tractor, pulled out the lift piston, and found the u-cup to have a rough place on the outside edge and a tear in the middle. I ordered the new paper gasket and u-cup along with some additional gaskets from Deere. Is there anything else I need to replace or look at that could cause the lift to leak down?
Thanks,
MACE
Mike M
04-14-2006 12:27:33
 Re: 1950 JD B and PCV 107622 power lift in reply to MACE, 04-14-2006 11:21:36
Maybe also put new o-rings in the housing to seal up where the coupler plugs go in ? All 4 the same size and hard to see. Should be alot easier since you have the valve off.
