G gas tank sediment bowl threads-solder,braze,or w
used to be jame
04-13-2006 19:38:57
Trying to replace fuel shutoff/sediment bowl. Twisted the sediment bowl threads lose in the bottom of my gas tank. Does that threaded ring need to be soldered, brazed, or welded to the tank?
Thanks,
James
430WLPG
04-14-2006 19:03:47
 Re: G gas tank sediment bowl threads-solder,braze, in reply to used to be james, 04-13-2006 19:38:57
The shop vac is NOT a good idea,most of those use a brush type motor and brushes spark when running.
JDBert
04-14-2006 07:46:41
Welding will creat to much heat and shrink and you will more then likely endup with cracks running outward from where you welded. I would solder OR braze it. The last one I did I heated up the area and removed all the old solder, I ended finding a fitting that sandwichs two gas proof neopreon washers (one inside the tank and one outside the tank). And had the right thread for the bowl. It is kinda tricky getting the threaded nut on inside the tank BUT it worked great and I did it on the tractor. If your worried about blowing yourself up, its not the gas that gets you its the fumes from the gas, just stick your shop vac hose in the fill hole and turn it on while you work (if your going with a "open flame" method of fixing it).
Mike M
04-14-2006 05:23:36
I think most of them were soldered ? At least that's what I'd use to redue it as it takes less heat. If you can find a large enough soldering iron it can even be done without worry of blowing yourself up. LOL A good hot soapy water pressure washing will help get the gas out if you need to take a torch to it.
Marty Z
04-13-2006 21:45:19
Mine was soldered on the inside and outside.That female coupling on the bottom of the tank has a flange on the inside that wants to spin when the tank starts to rust away. Or if the bowl was twisted too tight. At least that is the way mine was. Not sure how others were.
Good luck.
Tricky job.
Marty Z
Curtice Ohio
lloyd in sc
04-13-2006 21:19:02
every choice offered scares the h##l out of me!
