3010 clutch problem
Dean in iowa
04-13-2006 19:31:30
I have a 3010 gas. When it gets warmed up it is impossible to get into any gear unless you idle it all the way down. The dealer installed a new clutch because the old one showed very very slight warpage. The rest of the cluch looked very good. Still have the same problem. any ideas????
Mike M
04-14-2006 05:26:13
 Re: 3010 clutch problem in reply to Dean in iowa, 04-13-2006 19:31:30
Our 4020 gas did the same thing. I had to resurface the plates and fylwheel plus put in new discs. My plates were warped and I think that was the main cause.
Jared K
04-13-2006 20:11:03
Check your top shaft and synchronizers.
I have seen a couple that have had this problem.
Jared
Turtle Gears
04-13-2006 19:45:58
I have always seemed to have good luck always having flywheel serfised and always new clucht disk&presser plate & piolt bearing. my 2 cents T.G.
