12-volt setup
gmc ronnie
04-13-2006 13:16:28
if you have a 12-volt distributor, and a generator what would be better to use , a amp gauge or go with a volt meter.
John T
04-13-2006 14:38:08
 Re: 12-volt setup in reply to gmc ronnie, 04-13-2006 13:16:28
Ronnie, Either provides some degree of information, and its a matter of choice and opinion n preference, but since I like things ORIGINAL I would go with an Ammeter. Then if one had a "thing" for a Voltmeter one could still easily be added.
I just like looking down and easily seeing what net amps are flowing into (charging) or out of (discharging) the battery. An ammeter provides good resolution (20 to 30 amps + or -) to see exactly whats happening, while some voltmeters may not have the same resolution. To know if a battery is charging with a voltmeter, one has to see if its voltage is 12.6 (what a fully charged battery at rest reads),,,,, ,,,,, ,,,,, or somewhere between 13 to 14 or so (what a good charging system may cause),,,,, ,,,,, ,or less then 12.6 (what a battery supplying amps into a load may read if shes not being sufficiently recharged). Get the picture????? ???? Thats why I prefer an easy to read ammeter with good resolution.
Id start wiht the ammeter then add a voltmeter if it "turns your crank"
Just my opinion, either provides some degree of useable information
John T
