Cutting the axel
Crude K
04-13-2006 08:16:17
I need to cut 3" off of the axels on my B in order to get it in the shed for storage. I know it is not the best thing to do but I have no other choice to keep it inside. Should I just take the torch and cut them or can I cut the with the sawsall or are they to hard? Other than the negative of short axels is there any other concerns when cutting them.
Any and all feedback is always appreciated.
JDBert
04-14-2006 07:53:38
 Re: Cutting the axel in reply to Crude K, 04-13-2006 08:16:17
If you have access to a handheld band saw they work excellent, I cut the axes on a 7060 allis with no problem.
your john deere b
04-13-2006 22:41:41
 Re: Cutting the axle in reply to Crude K, 04-13-2006 08:16:17
PLEASE DON'T CUT ME!
DSK
04-13-2006 20:21:56
I'm sure there are many "correct" people out there grasping their chests about now, but if it were my B I would go ahead and torch off the axles as required and then clean them up with a 7" grinder. Get yourself a set of original axles and put them away in case someday you want to sell the tractor, or when you build a bigger shed and want to return the tractor to stock axles. Hurry in before the supply of B axles is gone.
P Browning
04-13-2006 21:42:19
 Re: Cutting the axel in reply to DSK, 04-13-2006 20:21:56
I am just a small bit surprised someone hasn't already offered a pair that have been cut. A brief trip to a salvage yard if one is close may prove intersting! (PatB)
Duane Larson
04-13-2006 13:20:39
Crude K,
If it is just a door problem, and you have room inside the building, can you back in at an angle? If your door is 90" wide and your axles are 96", you would have to back in at an angle of 20 deg or greater. Your tires would have to be pushed in far enough to give them clearance at an angle.
Geometry
04-14-2006 08:24:35
 Re: Cutting the axel in reply to Duane Larson, 04-13-2006 13:20:39
The tractor will move in if mounted on a dolly at 20 degrees. When backing in at 20 degrees, if the right axle clears, the tractor will move 6 inches to the left as the left wheel rolls to the door. If the axles are cut, you can get back to the "normal" wheel spacing by reversing the wheels. In jest, will your wife's car fit in the shed? Keep the tractor in the garage where it will be more convenient.
Ben.So.Tex.
04-13-2006 12:17:29
Think about it, If you ever have to pull the reduction gear cover off or the clutch pulley off you will need to widen the wheel to get enought room to work, and that 3inches may come back to haunt you. My two cents
You proably need a new equipment shed, now would be the time to tell your other half if you have one
Mike M
04-13-2006 11:04:58
Put in a wider door ? Or cut notches in the jambs for the axle to slip past ?
If you must cut them a very good way to do this is to jack up the tractor and put it in gear to turn the axle slowly then use a cut off saw. The dealer I saw doing this on a new tractor rented one of those large cutoffs built from a chainsaw.
Rekabnivek
04-13-2006 10:35:58
What I did was jack up the rear of the tractor, start the tractor and put it in hi gear. Then I used a hack saw, with a new blade, and put it on the axel where I wanted to cut. It took a a bit of time, but it did cut through. I did grind the corners off and drill a recess so they would look original.
Roy Suomi
04-13-2006 09:00:49
If you must cut axles...I would use an angle grinder with thin cut-off wheels. I use my Metabo 5" grinder to cut everything. I buy .040" wheels at the local welding supply house...
