F-I-T, '49 A vs. Model 60 rod number
Rutland
04-13-2006 06:28:08
F-I-T, I hope you can help. Before I spent $50+ on the JD 60 parts manual, which I�d probably only us once, would you be able to tell me what the casting number is for the JD 60 connecting rod, or are you into A�s only? Per your advise I�d like to replace my beat up A�s babitted rods with the insert type. AGKITS, for one, says they need the casting/forging number that�s on the rod. I�m sure they(AGKITS) know but they want you to tell them. Thanks in advance.
Tim
Rutland
04-14-2006 09:23:50
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to Rutland, 04-13-2006 06:28:08
JDBert, does Doug have both used and new? Also, where is this 'mother deere' web site, I can't find it.
Mike M
04-14-2006 10:26:43
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to Rutland, 04-14-2006 09:23:50
www.deere.com
JDBert
04-14-2006 09:52:27
Doug will only have used-Mother Deere IS your local JD dealer
JDBert
04-14-2006 07:58:20
I used 60 rods in my 51' "A" to get to the insert bearings. $150 apiece is TERRIBLY high. I gave $50 at a junk yard, new rod bearing will cost you $100+ for a pair, wrist pin bushings (if I remember right) were about $50 for the pair. Are your rods shot?
Rutland
04-14-2006 08:22:57
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to JDBert, 04-14-2006 07:58:20
JDBert, the old babbitt bearings have seen the course. If you can give me the address of a place where I can get 2 new rods with wrist pin bushings for $150 total please let me know.
JDBert
04-14-2006 09:01:49
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to Rutland, 04-14-2006 08:22:57
I got my rods from Worthington ag parts- I got the bearing inserts and wrist pin bushings from mother deere.
Try this number-I get all my parts from Doug now, I was just there on Saturday and I know he's got alot of parted 60's. You have to call him after 5:30 and leave a message if no one answers. Hes great to deal with and has fair prices.
Doug Strandberg
(507) 376-3865
Or his cell is usually the best
(507) 360-2140
Worthington MN
Rutland
04-14-2006 04:28:20
$150 each, not sure about the other question but I'll ask. They come with pin bushings, bolts & nut, no inserts.
Rutland
04-13-2006 11:34:01
Thanks frank and Mike, just got off the phone with AGKITS and they have what I need, A4648R. Now to covince the better half to let me use the plastic card. Thanks. Tim
Mike M
04-13-2006 12:22:10
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to Rutland, 04-13-2006 11:34:01
How much do they get for a pair ? Are they reconed or just used ?
Mike M
04-13-2006 07:00:21
Look in your A parts book they should be listed in there along with the bearing inserts numbers. Should be listed at maybe the bottom of the pages that the original style rods are on. A real late serial number A may even of came with those from the factory as they had the solid bushing type mains like the 60.
F-I-T
04-13-2006 07:30:41
 Re: F-I-T, '49 A vs. Model 60 rod number in reply to Mike M, 04-13-2006 07:00:21
Mike is correct. The numbers I gave you were for either the '60' or late "A", and I cross-checked the numbers in both parts books. Both engines used the same late rod, piston, bushing, pin.
