John Deere Crankshaft
Tony Kaluzny
11-26-1999 14:31:21
I need an opinion or two, about welding a cracked crank shaft for a John Deere Model 40 'c' crawler engine. The repair shop will weld the crank shaft but they won't guarentee that the shaft won't break. Could a remanufactured crank shaft be welded as well. What are my chances this repair is just a waste of money. I intend to use the machine once and a while and I am restoring the whole machine. Thanks for your help. Tony.
jarrod
11-29-1999 17:36:31
 Re: John Deere Crankshaft in reply to Tony Kaluzny, 11-26-1999 14:31:21
Later model John Deere engines have a problem with crackes starting from the oil holes in the crankshafts. Had a lot of them welded up by a local shop that does engine warranty work for John Deere. So you know it has to be good. Depending on the location and the depth of the crack will determine what your going to end up with. I think you could find a crank since that's not the only one in the world.
Britt
11-27-1999 16:43:44
Build up of worn bearing surfaces on crankshafts by welding has been around for years. If sent to a reputable shop that has a good track record in this kind of repair, you should have no problems. I have used welded cranks in Caterpillar, Cummins, Detroit, Murphy & Cleveland diesel engines, and never had a failure due to the weld process.
However, I would not choose to have a cracked crank welded, unless it was an otherwise unobtainable part. If this is indeed the problem with your crank, I would make every effort to find a "good" serviceable or reground crank. There is a heavy equipment paper called "Rock & Dirt" that sometimes has shops advertise this kind of repair. If you do have a crank welded, make sure that it has been properly stress relieved following the weld process.
Good Luck,
Britt
Clyde Scott
11-27-1999 06:04:34
Tony:
There are LOTS of people with parts tractors that can help you with your Crankshaft problem.. Don't think I would trust a "repaired" shaft on a restore project.. Just look for a "good" used one.. C. Scott
Nathan(GA)
11-26-1999 19:19:30
May outlast the rest of machine, but I wouldn't bet on it. That's a bunch of work to take a chance on. Go with new or remanufactured. If you weld it and put back together and it breaks, it will tear up more parts. A little more money now will be cheaper in the long run.
Good Luck, Nathan
Fudd
11-26-1999 16:43:39
I wouldn't trust a welded crank, it's not worth it if a new one is available.
DougS
11-27-1999 06:02:58
 Re: Re: John Deere Crankshaft in reply to Fudd, 11-26-1999 16:43:39
Tractor Pullers run stroked out welded cranks all the time. They trust them and the cranks perform well as long as the shaft has been stress relieved either by heat or extreme cold.
STMTS
11-26-1999 16:32:28
CT has reground shafts with bearings for$299.99 without exchange 1-888-8CT-FARM
Chuck
11-26-1999 14:51:46
why take a chance, get another crankshaft
James Borders
11-28-1999 13:23:31
 Re: Re: John Deere Crankshaft in reply to Chuck, 11-26-1999 14:51:46
If you know it is cracked now,can it and get you one that you know is servicable and don't waste your time or money .
