Creeping 3020 Powershift
TomNTexas
04-12-2006 22:57:50
I"m looking at a 3020 powershift that creeps forward very slowly while in a forward gear with the clutch presssed down. Can this be corrected through an adjustment or can I expect something more serious in the P.S. transmission? Shifting seems to be fine.
Thanks,
Tom
MSM
04-13-2006 01:15:05
 Re: Creeping 3020 Powershift in reply to TomNTexas, 04-12-2006 22:57:50
If it was cold(below freezing) when it did it,that is normal.The clutches are releasing but some creeping is caused by cold oil drag. On the other hand if the transmission was up to operating temp,there is a possibility that the foward clutches are warped which will give you a creep.Another possibility is that the inching pedal or dump valve may need adjustment or repair,It is not fully dumping drive oil pressure causing the creep.A pressure test would give you a better idea if there is indeed a problem.
