Help, Should I Buy This B?
cjdeere
04-12-2006 20:58:09
Help please,
I"m looking at a 1952 B, the guy wants $1500 for it . The tractor has new rear tires, good tin, roll-o-matic and a 3 point but the exhaust manifold has cracks in it , no seat pad, carb needs work, the wiring needs some help and he said he pulled the shifter out once while trying to shift and put it back in the wrong gear so it may not have 5th & 6th gear, he said I could take the shifter out and ( fish around for the right spot) . I am looking for a B in this late style... BUT... Thanks for any info.
Thanks, Chris
jturbo
04-13-2006 09:42:23
 Re: Help, Should I Buy This B? in reply to cjdeere, 04-12-2006 20:58:09
Is it worth $1500? I don"t have a picture to gauge the condition but the parts are worth more than $1500. Tires are $450, 3pt is 800-1000, etc. Start at $1000 or $1200 and see if he will negotiate. You could spend a $500-1000 fixing it up and still only have $2000-2500 in the tractor. Most old 2 cylinder have bad manifolds so that is not a big issue...$150-185 to fix. If you are not mechanically inclined then it is a different issue..don"t buy a fixer-upper.
cjdeere
04-14-2006 05:34:19
 Re: Help, Should I Buy This B? in reply to jturbo, 04-13-2006 09:42:23
Thanks for the info, I bought it but not for $1500. I feel like I got a good deal. I'll start the restore in a few weeks after I get the Jeep done. Thanks Agian, Chris
Hayfarmer
04-13-2006 07:32:07
On the other side, new tires on the back, probably $500 there,how are the rims? 3 point, is it an 800/801 or after market or homemade, value there, good tin in a positive. Rolomatic if good also has value. May be a simple fix to transmission. On the other hand there are a ton of Bs out there but no more being made. I don't see many for sale in my area, not like in the past years. Maybe off er $1000 and go from there.
dab
04-13-2006 01:08:52
I agree with jdr60. A little much for what you are getting. But you said it all at the end of your statement. BUT... when you second guess, walk away. Look around now, prices are dropping every day currently and I think it has to do with the gas.
JDR 60
04-12-2006 21:33:42
I would go for 500 to 750 on it tops. it sounds like it has more bad points. there are tons of late b's out there than need little work for the same money. here is how i would figure it. 70 for the carb work, 60 for the wiring, 50 for the seat and God knows for the tranny $150??? if there is a serious problem then much much more. if it was a scarce type like a 530 or the like I would say yes to the price but that is steep for a lot of problems
