Model D Valve seat inserts
Big_Roy
04-12-2006 16:54:16
I have come up with two valve seat inserts that are labeled for the model D with part number AB116 written on them. They were in a box of misc. valves and guides... So far I have not been able to find anymore info on them. I'm hoping that these will fit my '48 D that I'm currently working on. Will they work and do any of you know a current part number for the D valve seat inserts? Thanks.
Larry806
04-12-2006 20:03:50
 Re: Model D Valve seat inserts in reply to Big_Roy, 04-12-2006 16:54:16
All the D"s take the same valve seat. Also the intake & exaust are the same at 30 degrees
I forget the sizes right now but the outside should be 2 3/4
Larry806
04-12-2006 20:09:36
 Re: Model D Valve seat inserts in reply to Larry806, 04-12-2006 20:03:50
Forget to say the cutter is 2 3/4 the interference is made in to the seat diameter
J. Schwiebert
04-12-2006 18:41:17
Do you have dimensions for those seats? Also stick a magnet to them. Are they alloy or cast?
Big_Roy
04-12-2006 19:53:29
 Re: Model D Valve seat inserts in reply to J. Schwiebert, 04-12-2006 18:41:17
The outside dia. is 2.756"
The inside dia. is 2.310"
And they are 0.375" thick
And they are magnetic.
While looking at them this time I did notice this printed on the outer rim:
M.W.W.541
