BR axle pivot pin
John in IN
04-11-2006 19:29:11
The front axle pivot pin on my BR seems to be worn. They are no longer available from Deere. I thought I might be able to make one. Is this a heat treated pin or not? What kind of steel would be best? I have not take it apart yet.
Thanks,
John
Marty Z
04-11-2006 22:14:41
 Re: BR axle pivot pin in reply to John in IN, 04-11-2006 19:29:11
You can go heat treated if you want but my guess is that any steel pin that you can turn to fit will outlast you. If you make one to fit the best it can, when the tractor weight sits down on it , it will be fine. The hole is probably ovaled out some too but don't worry about it. Just grease it up and it will ride OK. I used regular round bar stock on my 35 "D" and it holds that beast just fine.
Marty Z
