Dry Filter Conversion
RedJD
04-11-2006 15:35:56
Has anyone converted an oil bath canister to take a dry filter on a styled A?I need to know the part number for the right filter to fit inside the canister.Thanks
JDBert
04-12-2006 13:17:04
 Re: Dry Filter Conversion in reply to RedJD, 04-11-2006 15:35:56
Gut the can, take the center cup out of the bottom can (3 spot welds). Get a 4230 inner air filter, go find a machine washer that fits the rubber seal on the filter and then get a piece of ready rod (threaded rod- what ever you call it) that the same size as the nut for the filter. Now make a triangle out of 3 pieces of rod weld to the machine washer and where the 3 pieces come together use the reamaining ready rod to come down and through the mounting hole of the filter cut that to length and then weld the machine washer to the air can put the bottom on and there ya go. The filter actually works in reverse the air blows through it and then in the engine instead of being sucked in and then in the engine. Works great I did it about 6 years ago on my 51' "A".
Mike M
04-12-2006 06:07:22
If your tractor pulling just leave your oil out and run it. If your using your tractor the oil bath system will filter better and cost far less to change.
Jd 40203020
04-12-2006 05:59:13
For some reason, I bet most people here are going to ask why you want to do that, and then say that they don't know how.... I don't know exactly how eithor, but I have done something similar. I have changed my early 4020 to a dry filter. I used a K&N filter, and bought the biggest one I could fit in the can. This is not a quick easy change! It takes some fabricating and touchy welding on the thin metal of the can. And once you start there is no going back to the oil bath without buying another can, so don't jump into it too fast! If you want to know more e mail me.
skip33652
04-12-2006 07:12:41
 Re: Dry Filter Conversion in reply to Jd 40203020, 04-12-2006 05:59:13
I know that someone is going to jump down my throut for saying this but a k&n fiter in dusty conditions will shorten you engine life considerably. they evidently let to many fine particles through. I know of several diesel pickups that the blocks wore so bad they needed bored in less than 80,000 miles a 302 ford that the block would not clean up to .040 at 72,000.the k7n seems to work fine on the street where the air is fairly clean but not on the back roads. Paul
JD 40203020
04-12-2006 07:51:05
 Re: Dry Filter Conversion in reply to skip33652, 04-12-2006 07:12:41
Maybe? I don't know! The one I am using does not come from the pickup line. Its one of the racing filters, and is probably twice as big as the pickup ones. With the trucks you seen, did they accidentally make a small hole in the filter while cleaning it?
I don't know if there is any diffeerence, and I am just trying it, and telling our friend here that it can be done. My only reasoning is that for pulling it is a lot better than pulling the oil cup and having nothing, and so far for farm work it seems to be ok. I guess I will find out some day how well it works!
buickanddeere
04-12-2006 20:04:15
 Re: Dry Filter Conversion in reply to JD 40203020, 04-12-2006 07:51:05
The K&N filter is fine on the race track,on a boat or airplane. In a dusty field? Keep the two paper filters if dirt stopping is desired.
