JD 420 Hydraulic Pump needed asap!!
leinhit
04-11-2006 12:22:02
Guys, I need a good hydraulic pump for my 1957 JD 420. I found that a bearing went out and the loose metal scratched up everything, including the gear pocket side walls.. both sides of the gears, and of course the pockets.
Anybody have one they can part with?? Or anyone know of a supplier? I've been looking..
Steve
ralph oregon
04-11-2006 21:05:29
 Re: JD 420 Hydraulic Pump needed asap!! in reply to leinhit, 04-11-2006 12:22:02
i have pumps for M-40-420 OR PARTS. ralph
leinhit
04-12-2006 07:43:49
 Re: JD 420 Hydraulic Pump needed asap!! in reply to ralph oregon, 04-11-2006 21:05:29
Ralph, I just sent you an email, hopefully it goes thru.
Just in case it doesn't, my email address is [email protected]
I was asking if you have the pump, is it used or rebuilt? Have you gone thru it to see how well it works? I hate to get one just as bad as mine ! :)
and of course how much do you want for it? Give me a reply email direct if you would.
Thanks for giving me the help..
Steve
johns48b
04-11-2006 18:17:39
fellows try marlyn smith in iowa at 712-489-2570. i don't know if he has what your looking for but he has lots of "stuff". tell him john t in n al says hi
leinhit
04-12-2006 07:37:49
 Re: JD 420 Hydraulic Pump needed asap!! in reply to johns48b, 04-11-2006 18:17:39
I will, Thanks!
steve
LFN
04-11-2006 16:31:02
Must be the day for pump problems, just opened mine up, only on an MT. The center(surrounds the gears) housing is broken (Part # M1029T) The 420 uses the same part #. Is there a chance your center housing could be useable? It wouldn't have to be perfect mostly hold oil. as it wont be a working tractor just something "purdy" to look at. LFN
ralph oregon
04-12-2006 09:53:08
 Re: JD 420 Hydraulic Pump needed asap!! in reply to LFN, 04-11-2006 16:31:02
why don't you take the pump off and put the cover for the hole. i have them for $20.00 plus shipping. ralph
lfn
04-12-2006 11:22:50
 Re: JD 420 Hydraulic Pump needed asap!! in reply to ralph oregon, 04-12-2006 09:53:08
I also left an E-mail, but I suspect the hidden address thingy don't always work. How much do you need for good used center section Part # M1029T
leinhit
04-12-2006 07:40:41
Well, if its not gonna be a working tractor, then mine but just work.
I'll let you know as soon as I know what my plan is. Some places want a core exchange for pumps, but if I buy one outright, I wouldn't need this one.
Hopefully I will have something in hand within a week.
I'll get back to you as soon as I know something positive.
Steve
