How to split hydrolic hoses from one set of lines
Youngin
04-11-2006 09:46:41
I own a John Deere 3010 gas tractor and I was wondering how I could run separate lines for say, a disk for instance while operating a loader on the only lines given for that tractor. Any help would be much appreciated.
JMS/MN
04-11-2006 19:24:27
 Re: How to split hydrolic hoses from one set of li in reply to Youngin, 04-11-2006 09:46:41
I assume the 3010 is similar- here's how to get an extra valve hooked up. Forward of the brake pedals is an elbow coming out of the rigbht side of the tractor. It feeds the rockshaft. Replace the elbow with a 'T', and feed your extra valve with that. Valve return needs to feed back to oil sump. Can be multiple valves too. Put quick couplers in the two hoses so yu can disconnect them when not needed.
Gerry_Luzerne_MI
04-11-2006 14:44:04
Youngin: If I were you I would have SCV's installed for the tractor and do things the SAFE and right way.
Here is a valve that I believe Mike was talking..
Link
Gerry
Mike M
04-12-2006 06:13:47
 Re: How to split hydrolic hoses from one set of li in reply to Gerry_Luzerne_MI, 04-11-2006 14:44:04
That's the push pull type you can use. They will work but kinda a pain in the rear if you need to switch real often. I do agree that running a seperate valve just for the loader and freeing up the remotes would be a better way to go.
Mike M
04-11-2006 10:18:19
There are companies makeing splitter valves for just that and they have an electric solenoid to change them from one set to the other. Or you can buy a manual type push pull selector and plumb them in. Check out your local farm store or tractor dealers they should have them.
