6v - 12 v difference
gmc ronnie
04-11-2006 02:13:07
how can you tell the difference from a 6-volt generator , to a 12 - volt generator .
John T
04-11-2006 05:30:12
 Re: 6v - 12 v difference in reply to gmc ronnie, 04-11-2006 02:13:07
Ronnie, Unless youre armed with data and specifications and know at what RPM youre spinning a generator it may be difficult to know what voltage its supposed to be from measuring its open circuit output voltage, its more interested in supplying amps into a load then serving as a voltage reference/source. Regardless what its supposed to be, 6 or 12 volt, Ive used 6 volt units to charge at 12 volts simply by using a 12 volt Voltage Regulator and vice versa. NOTE Im NOT saying thats the proper or good or engineering way, Im just saying Ive done it n it worked no problems. If using a 6 to charge 12 it may perform marginal (low amps) while using a 12 to charge 6 would likely perform better. A genny dont necessarily know what voltage its supposed to produce, its increased by turning it faster or pumping more amps through its Field windings (part of what control the VR does).
If you had 2 similar gennys side by side a 6 and a 12 volt, one (the 6 I believe) would have closer spaced commutator bars.
Good luck, let us know
John T
Bob
04-11-2006 02:22:26
If the generator is working, you can check the open-circuit voltage with it running at moderate speed. A 6-Volt unit will put out well above 6 Volts, a 12-Volt unit will put out probably close to 20 Volts.
I'm not sure if this is an ABSOLUTE rule, Delco 6-Volt generator tags generally have a BLACK background, tags on 12-Volt units generally have a RED background. (As well as 24-Volt units.)
Also, if the tag is present, simply Google the first (numerical) part of the number. Often, you'll get "hits" as to the original application of the generator, as well as it's voltage.
