2940 ujoint
SDdeere
04-10-2006 21:21:23
We have a 2940 made in Mannheim Germany. One of the front ujoints in the front axle went out. We ordered a new one from John Deere and it was too small and too short, but they said it was for a 2940 US specifications. They told us that ours was a European spec. model and it was a black market tractor and shouldn't even be here. They couldn't seem to be able to get the right part. Our ujoint measures 1.335" wide on the caps and is 3.703" wide from cap to cap. We were wondering if anyone would know anything about this and could help. Thanks from SD
Here are the numbers on the side of our old ujoint
511232
200001
2112
Bob
04-11-2006 01:39:32
 Re: 2940 ujoint in reply to SDdeere, 04-10-2006 21:21:23
I'm in ND. Your tractor MAY have come out of Canada.
Try giving one of these dealers a call, in Manitoba, with your tractor serial #, and front axle serial #.
I have had good dealings with both:
DB Murray Ltd.
Melita Manitoba
Corner of Hwy 3 & 83
Box 669
Melita, Manitoba
Canada
R0M 1L0
Tel: (204) 522-3341
Toll Free: 1 800 805-0495
Fax: (204) 522-3176
Countryside Equipment
Brandon, Manitoba
1660 - 18th Street North
Brandon, Manitoba
Canada
R7C 1A5
Tel: (204) 728-7043
Fax: (204) 726-1540
Bob
04-11-2006 01:55:26
 Re: 2940 ujoint in reply to Bob, 04-11-2006 01:39:32
P.S. ...
(Is this U-joint for the front driveshaft from the tranny to the axle, or a does it go in one of the front steering knuckles?)
I just looked on JDPARTS.
The part # of the "U"joint kit they show as fitting the front axle shaft in the steering knuckle is # AL32994.
It's measurements are:
Cup diameter: 1.339 IN
Across the cups: 3.819 IN
This would seem a bit LARGER than what your are measuring your original joint, rather than the one your dealer got for your which you said was small.
Post back as to whether it is the joint next to the wheel you are looking for, or a joint for the front driveshaft. They show TWO options for the front driveshaft joint kits.
lonzo
04-11-2006 01:36:20
I had toget a parts book from Deere that fit the tractor that i had in my shop on time , I had no more trouble getting parts, i would think you that Deere would could do the same thing for you.
