Hey bob or ?-24V starter
bubba 2
04-10-2006 20:01:33
Starter is bad on my 3020.Who has the best deal on converting it to a 12 volt system?
Andrew Lambert
07-20-2006 17:49:45
 Re: Hey bob or ?-24V starter in reply to bubba 2, 04-10-2006 20:01:33
Bob, could you send me the info about converting to 12 volt. That's what I'm trying to do. Thanks
Bob
04-10-2006 20:17:18
I vote to keep it 24-Volt, unless you need a LOT of Amps at 12-Volts.
If you are determined to convert it to 12-Volt, you need a 12-Volt starter, and a 12-Volt alternator. A common Delco 10SI will do for the alternator.
The wiring changes are simple. I'll email you the information, if you'd like.
The fuel gauge may not be accurate after the conversion, unless you change out the sender adn gauge.
