4020 synchro trans problems
hank n tx
04-10-2006 17:02:31
i started my 4020 up sat morning and i couldnt get her in gear. grinding bad especially trying for 1st. wouldnt go into reverse either. i kept fiddling with it and i believe i went down to about the 3rd range and she finally went into i believe 5th gear.after that i was able to shift into 1st and reverse. my shifter mechanism is fairly sloppy. iv'e had problems trying to get the shifter into the slots but after fiddling with it i'd get her in any gear i chose. but this time she wouldnt go into gear. than i tried it again that afternoon and the same thing happened. again after fiddling with it for awhile i was able to get her into a higher gear and after that she would go into the lower gears plus reverse. what needs to be done to fix the problem.is it major? tahnks for taking the time to help
hank
HTR
04-11-2006 03:54:55
 Re: 4020 synchro trans problems in reply to hank n tx, 04-10-2006 17:02:31
This sounds like more like the clutch sticking, than a transmission problem. Probably has oil on the clutch disk.
lonzol
04-11-2006 02:08:35
Will the shifer work fine when the engin is the
dead? If still doesn't shift right look at shifter parts under the dash, remove the right battery box and unhook the 2 rods from the shifter arms and then move the arms by hand, if they work fine and the gear shifter works then you got problems in the clutch parts
