3020 J.D. Injector Pump.
Ron R.C.
04-10-2006 16:51:58
I have a 3020 J.D and it seems to not have the power it should have. Recently overhauled and new injectors put in. It doesn"t want to get down and pull like it should. Could injector pump need rebuilding and can I do it myself. Any suggestions?
Ron R.C.
04-11-2006 19:38:42
 Re: 3020 J.D. Injector Pump. in reply to Ron R.C., 04-10-2006 16:51:58
Thanks for the help. I checked the timing and it is set to the right timing. The guy I bought the tractor from said the pump had been rebuilt(didn't specify who did it) but it hasn't had the power it should. I had a 3020 before this one and it would light up the sky when you put the hammer down on it. I guess I'll pull it and sent it to the shop to get it checked out. Thanks again.
RFH
04-12-2006 12:07:19
 Re: 3020 J.D. Injector Pump. in reply to Ron R.C., 04-11-2006 19:38:42
Funny - I bought a 3020 from a fella who said the pump was just rebuilt also. About 30 hours later the tractor would not start and the pump had to come off and go to a real diesel mechanic. My advice - take it to a reputable outfit who will stand by their work. Some folks idea of a rebuild is a lot different than others.
ET
04-11-2006 05:29:10
Give the pump timing a quik check. The maks should line up at TDC.
msb
04-10-2006 19:56:22
If its been over 3.000 hours since the pump was rebuilt then it would be a good idea to hgave itv done.My advice woukld be to have a qualified technician rebuild the pump.There is a lot to know about rebuilding those pumps that only experience can teach.You may be able to disassemble and reassemble it ,but that is not a rebuild in my book.
