This post is to provide the correct version of the Wire Run List for John Deere Model H" Tractors and is in response to a wire run list I posted in answer to the "John Deere H Wiring" thread of a few days back. The list I posted back then depicted the ammeter polarities backwards!I would like to than RavGardner for his persistence and patience on this one. Here's the right version: John Deere Model "H" Wire Run List (Corrected 4/10/06) Wire #'s 1, 2 and 3 to individual lamps are 14 AWG; when two or three are combined, wire size is 12 AWG, black. Wire # 4, Gen (F) to Light Switch Resistor terminal, 14 AWG, yellow w/green tracers. Wire # 5, Cutout Relay (BAT) to Ammeter (-), 10 AWG, yellow w/black tracers. Wire # 6, Ammeter (-) to light switch (B) is 12 AWG with in-line fuse holder, yellow w/black tracers. Wire # 7, Ammeter (+) to Starting Motor is 10 AWG. (Wire # 7a for lights only, no starter), from Ammeter (+) to Battery (-) is 10 AWG, yellow with black tracers. Wire # 8, cable from Battery (-) to Starting Motor is 1 AWG. Wire # 9, Battery (+) to Tractor is a Ground Strap sized at 1 AWG. Wire # 10, Cutout Relay (GEN) to Generator "A" is 10 AWG, black. All conductors are stranded and cloth-covered, and all terminals are closed loop type, no spades. Light fuse size is 20 amp -- smaller or larger will not do! ++++
