JD 4010 LP Missing Out
Larry Zamzow
04-09-2006 18:31:59
I put an electronic ignition on my JD 4010 LP about two years ago. I thought all my problems went far away. Now I have a problem with it taking the gas when you speed up the throttle. The tractor starts great & sounds great. Takes the throttle & everything. After operating for 10 to 20 minutes, it acts like its running out of fuel, but its not out of fuel. One time, I charged the battery overnight & ran it the next day for 30 minutes or so & thought that was it. Now its doing it again. Please give me some ideas. I changed one of the battery cables that was partly disintegrated. I also changed out the rubber hose that connects the air intake to the carburetor, thinking it was sucking air. The air cleaner is clear and not plugged up. All of the spark plug wires and rotor cap is lubed up with dielectric grease. All clean there.
Thanks.
Larry Zamzow
04-10-2006 05:34:43
 Re: JD 4010 LP Missing Out in reply to Larry Zamzow, 04-09-2006 18:31:59
I understand what ya'll are talking about regarding the valves. And, yes I had been turning around on those. I went to the barn late last night & turned both valves off completely. Then I started it up & ran it & slowly & partially opened the valve I usually run it on. For the five minutes or so I ran it, it sounded good and strong. I think this may have been my problem. I run it more today when I get home from work. Thanks for the replies.
Larry Zamzow
04-10-2006 18:21:09
 Re: JD 4010 LP Missing Out in reply to Larry Zamzow, 04-10-2006 05:34:43
I ran it 20 minutes again tonight. Ran perfect, then all of a sudden it acts like its out of fuel again. I guess I'll have to see if the filter in the fuel lock strainer is clogged; although I put a brand new one on last year. I think I've also replaced the valve guts since the seals were out before. Any more thoughts?
Thanks
Glen in TX
04-11-2006 21:17:10
 Re: JD 4010 LP Missing Out in reply to Larry Zamzow, 04-10-2006 18:21:09
Does it start missing or just pull down and die or not quite? Might carry along a extra spark plug and wire so you can check it right after it dies for fire. If no fire then you got other problems to look for like wiring or a bad coil and condenser. If fire then you can keep looking for fuel or air intake problems. Make sure the intake and air cleaner are clear too. If it was sitting for a while or old filler hoses been used or old lines on it and filter gets lots of black in it you may need new hoses? I had to flush one out to get rid of that black stuff in it. If was sitting a long time or used some old fuel and you suspect moisture on a LP you can put a pint or so of some alcohol in the filler hose before connecting up to fill tank and it will help disperse moisture just like with other fuels. If lots of black crud in there though it can clog it worse till you get that cleaned out first.
Larry Zamzow
04-12-2006 05:56:17
 Re: JD 4010 LP Missing Out in reply to Glen in TX, 04-11-2006 21:17:10
It starts missing & gets worse. If you idle it down real low I can make it back to the barn & it doesn't miss, unless its under load. It acts just like its out of fuel; but it's not. I have electronic ignition & the coil is new. The tractor has not sat for long periods of time between uses. I use about 250 gallons of fuel per year. Also, the fuel/lock strainer (I guess where the filter is you are referring to)is almost brand new. Also, I've recently (within the last year or two)change out the valves (or at least the part that comes out). I don't know what to think. Oh, the air cleaner bowl is clean.
Glen in TX
04-12-2006 08:37:32
 Re: JD 4010 LP Missing Out in reply to Larry Zamzow, 04-12-2006 05:56:17
Others thoughts are if you shut it down after missing and let it cool off does it run fine after restarting to full throttle then? If so would suspect ignition or wiring. Check throttle linkage action, governor and governor spring action or if broke. Could be regulator/vaporizer kit time? Collapsing intake hose? Collapsing fuel hose or other restriction. Excess flow discs can also still give trouble even though valve kits were installed and only way to see those is pull the valves. If valve is opened fast with line loose they should shut off from the disc inside.
Glen in TX
04-10-2006 11:26:35
Just want to run on vapor till it's warmed up good. You want valves all the way open or all the way closed. If it misses and balks on liquid may need to check the vaporizer and water lines for good flow or plugging also and thermostat. Watch for frosting in areas on valves and lines too and that can indicate a restriction. Had valve stems mess up too and your local LP dealer can get new kits or valves if they turn out to be a problem. I do it and also JD recommended to turn off liquid valve and run on vapor for a while before shutting down to relieve tank of some pressure for easier filling later. Also run the engine till it runs out of fuel and this will relieve pressure in system and keep high pressure from building in warm weather when not in use that can cause damage on regulator or system parts.
Glen in TX
04-09-2006 22:14:20
I'll agree the excess flow valve discs can cause problems like that and had to replace valves on a 520 LP because of that. Alway open or close the valves slowly to avoid the safety disc inside valve sticking or slamming shut. How much black stuff or black bbs are in the filter? Some is going to be there but if it has a lot or moisture too the tank could need flushing some. Does it still have good hot blue spark on ignition after pulling down or dying? If not it could also be a bad condenser or coil when heating up and expanding inside losing contact or shorting out or also other wiring expanding after heating and losing contact. A light silicone or lithium grease film is fine for better current contact but I'm not a big fan of using excess amounts of that synthetic dielectric grease. It isolates from moisture and promotes heat flow but doesn't promote a better contact for current. The lithium grease is better in spark plug boots. On LP engines you also want the spark plugs gapped at .015" - .018".
430WLPG
04-09-2006 19:23:46
There is a thing in those fuel valves called exess flow meaning that if you were to get one of the valves broken off and they snap shut and there would only be a small match stream of gas instead of a 3/4" stream. Any way after those valves get old their spring gets weak and when you start drawing on that valve it will snap shut also.Are you turning both valves on when this happens? If not try turning both on.And there should be a filter strainer built into the electric shut off valve.You have to turn off the valves and take out about 6 screws to actess the filter,you might remove it and try it without the filter and see what happens.
