Deere AMT 626 Gator Clutch question
Steve Mahler
04-09-2006 18:31:26
Apologize to put this in the deere 'tractor' forum, but I just bought an AMT 626 and have question about the centrifugal clutch - I have read online that these things always grind or crash gears when shifting...is that normal or can I adjust the clutch to engage at a higher RPM...?
Also wondering if anyone has found an aftermarket muffler that is quieter?
Thanks
Ken Cepek
07-23-2006 14:22:01
 Re: Deere AMT 626 Gator Clutch question in reply to Steve Mahler, 04-09-2006 18:31:26
I just now read your question. The owner's manual states that you should never grind when shifting. Before shifting, the machine should NOT be moving, the engine speed at very low idle, & then shift BRISKLY from neutral to forward or reverse. It is then easy to kill the motor when you push on the gas pedal. I foumd that if you start the engine, let it idle for a minute, and then GENTLY press on the gas, it will work fine. It's a mater of forming a good habit. Hope this helps. My wife & I are very happy with ours!
Ken C
Doug in IL
04-11-2006 06:50:03
The only thing I have found to help lessen the gear grinding, is to lower the engine idle speed.
Larry Zamzow
04-12-2006 13:58:05
 Re: Deere AMT 626 Gator Clutch question in reply to Doug in IL, 04-11-2006 06:50:03
What I do is halfway go to reverse, then push lever to go forward. Do the opposite for reverse. No grinding.
