I could get good at this (splitting my 1010)!
lloyd in sc
04-09-2006 15:01:04
Split my 1010 to rebuild clutch & pressure plate. Put it back together & then split it again (failed to adjust clutch levers). Put it back together & used impact wrench instead of torque wrench (broke off bolt). Drilled out bolt w/left handed bit & reinstalled pressure plate, drilled out other broken bolt (wrong colum 1/2" bolt NOT 9/16") Turned down torque setting & reinstaled plate.Put tractor back together & found retaining clips not installed, split tractor again, fixed that. Put tractor back together & found broken spring that retains PTO shaft. Found replacement spring, split tractor & put spring back in & then put tractor back together again. Started this morning about 7:30 & just now finished. Got so bad I quit being suprised! Still had a good day working on it. What can I say.
Jeff NwOH
04-09-2006 18:57:34
 Re: I could get good at this (splitting my 1010)! in reply to lloyd in sc, 04-09-2006 15:01:04
I've got an R like that. Nothing "takes" on the first try.
Tom in Mo.
04-09-2006 17:14:38
Hmmmmm mm. A bit of bad luck for sure. I hate when that happens. Hope all is well now!
