51B Starter Drive
James Nauert 42
04-09-2006 14:14:05
The drive on the starter on my 51B went to heck today it is a remanufactured on by a co. named Arrow i took the drive out that says arrow on it also. My partsbook says it should be a delco 1107942 are the drivs for this year B all the same? Who is a good sorce?
TBJ
04-10-2006 03:56:38
 Re: 51B Starter Drive in reply to James Nauert 420W, 04-09-2006 14:14:05
I recently had the starter drive go out on my 49 B. Took it to a local Auto Electric repair shop and they replaced the drive, replaced the brushes, cleaned and adjusted rest of starter. All for $65 with one year warrenty.
Bob
04-09-2006 16:46:25
Your post is a little confusing, at least to me. Are you saying you have had TWO rebuilt starter drives by Arrow Rebuilders that have failed???
Ignition timing set too early, a bad flywheel ring gear, or too much crankshaft endplay can all destroy starter drives.
1107942 is the Delco number for the COMPLETE starter, I believe the Delco number for the drive is 1909771.
Deere has the drive, under that part number, for $165.00, and a complete re-man starter for $222.00. What a deal!
Is there an electrical shop in your area that sells Wilson products? I have had very good luck with their stuff.
