'49 A upper water pipe
Nicolas
04-08-2006 14:21:22
I need to replace the thin walled section and have read the method on here of heating it with a torch to melt the braze. My question is, do I need an acetylene torch, or will a map torch get hot enough? Any other tips or suggestions are greatly appreciated, this is my first attempt at this. Thanks, Nick
Maark
04-09-2006 08:48:47
 Re: '49 A upper water pipe in reply to Nicolas, 04-08-2006 14:21:22
K&K have the replacement pipes. Bottom might be available at a muffler shop. K&K has the correct bends for upper replacement.
Rutland
04-09-2006 04:40:50
I need to replace both upper and lower water pipes, can you tell me where I can get them? Thanks,
jdhbag
04-09-2006 05:16:23
 Re: '49 A upper water pipe in reply to Rutland, 04-09-2006 04:40:50
Try Sharp's (417) 933-2253
Maark
04-08-2006 16:52:47
I usually cut the pipe off as close as I can to the casting. Then use an acetalene torch to remove the remainder. You will need the acetalene torch to braze it back in.
Mike M
04-08-2006 16:42:20
I bet an acetylene torch will be needed. I cut through the pipe on the inside of the casting then clamp some vise grips on the piece sticking out then heat from the insides one area at a time then roll it up with the vise grips as I go.
