G flywheel retainer
used to be jame
04-08-2006 13:49:28
The cap which is bolted on the outside center of my flywheel is broken and off center. Does this hold the flywheel in place? Do I just replace it, or are there any adjustments that need to be checked relating to this cap? I've heard of the flywheels coming loose, moving to one side or the other and causing lots of damage. Do I need to worry about this, or do I just bolt on a new center cap?
Thanks
James
Miller49G
04-08-2006 14:14:08
 Re: G flywheel retainer in reply to used to be james, 04-08-2006 13:49:28
That is the ratchet for hand starting the tractor. It doesn"t hold the fly wheel in place. There is 2 bolts that hold the fly wheel on they are on the inside behind the fly wheel. So as long as the 2 bolts on the inside are tight you don"t have to worry about it.
