35 A oil Pressure
Randy in AZ
04-08-2006 07:10:08
How can I verify oil pressure? The "pop-up" is up OK by spinning the flywheel manually.
P Browning
04-08-2006 19:00:31
 Re: 35 A oil Pressure in reply to Randy in AZ, 04-08-2006 07:10:08
Randy -- there is no port on your tractor where you can connect a gauge to measure oil pressure. For Model A tractors (1934 & 1935), JD techs had to mount a special oil filter cap, and in the cap was brazed a fitting to accept a gauge. Field Service Bulletin 60-S (4/15/36) illustrates the technique. If you would like a copy of that bulletin, shoot me an e-mail by going to www.jdhpubs.com and selecting the CONTACT ME button. Ask for FSB 60-S (4-15-36), pages 1 & 2. From A-424025 and up, oil pressure can be measured at the 1/8" NPT drill plug on the right-rear side of the governor housing. This is where the gauge is normally mounted on the unstyled A series from 1936 thru 1938. (PatB)
Randy in AZ
04-08-2006 19:24:33
 Re: 35 A oil Pressure in reply to P Browning, 04-08-2006 19:00:31
Thanks Pat, E-mail is on the way.
Randy in AZ
04-08-2006 17:26:57
Thanks for the reply, I have a guage in that port, but it shows no pressure. I suspect that port is above the piston that drives the pop-up, so the oil will feed into the governor housing, but I don't know. Is there any other place to access the oil pressure in this year engine. ??
Maark
04-08-2006 12:07:05
If the Red-Head is coming up at hand crank speed, oil pressure is ok.I wouldn't worry about it. But you may want to put a guage in the 1/4" pipe plug located on the gov. housing over by the magneto to satisfy your ?.
