630 RADIATOR REMOVAL
TIMAR
04-07-2006 20:45:22
What is the correct way to remove the steering shaft from the front pedestal to lift the radiator out of a 630? Or is there an easier way to get it out?
F-I-T
04-08-2006 11:07:36
 Re: 630 RADIATOR REMOVAL in reply to TIMAR, 04-07-2006 20:45:22
Manual steering? Power steering?
If manual you can remove the worm casing from the side of the front pedestal. Id it's a power steering pedestal, it's the same approach, but you should mark everything carefully so that you can return it to the correct position.
A parts book is very helpful.
Frank
