36 B Babbitt Rods
CalJim
04-07-2006 20:09:01
Hello,
Restoring our 36 BN. Machine shop called today, the crank needs to be turned. Can I have the babbitt removed and put in undersized inserts? Or can I swap the original B5R rods for the newer B3201R with inserts? Thank You CalJim
Maark
04-08-2006 11:32:56
 Re: 36 B Babbitt Rods in reply to CalJim, 04-07-2006 20:09:01
What the machine shop found was likely that the crank is egg shaped. Pretty common on these old tractors. There's alot of them running out there with that problem.It's only 70 years old. Will run a long time like that.Usually remove shims at the rod until tight, then replace one.
Theodore t. moore
04-08-2006 09:48:23
I rebuilt a 43 LA this year. I found the correct inserts, sent them to the machine shop. They bored out the babbit, and fitted the inserts to my crank size. Works great, good oil pressure,etc. I would try to get the correct inserts before I had the rods rebored. Good luck!
