1952 JD BN still knocks!!!
Deeretrax
04-07-2006 19:38:30
I have a 1952 John Deere BN. I had baught it from a neighbor who didnt use it anymore because it knocked really loud and he thought it was just in need of a overhaul. Well, I started tearing into it and everything really looks fine. Someone told me to try to adjust the flywheel for thats what many of them needed after a while. The flywheel seems externally fine. It isnt loose at all. It feels pretty good. So,I just thought I would turn the flywheel once and see maybe if the noise would be coming form here. Keep in mind that THE PISTONS ARE NOT HOOKED UP. So, I turned it fairly slow and sure enough, there was a "PING" noise at one point of the turn of the flywheel. Does anybody know what this is that is causing it? Thanks in advance!
Kurt_JDB
04-08-2006 07:55:33
 Re: 1952 JD BN still knocks!!! in reply to Deeretrax, 04-07-2006 19:38:30
If you have a magneto, you could be hearing it "trip" after wind up, which it will (should) only do at slow speed. It is also possible that the bearing in the reduction gear cover is shot, and that the reduction gear is loose on its tapered shaft or is otherwise banging around.
You can get a look at this bearing by removing the small cover on the reduction gear cover. Also, if you remove the clutch assembly, you can grab hold of the reduction gear and see if it wiggles around.
Kurt
BottomB
04-08-2006 07:11:01
Deeretrax take the clutch cover off and check the clutch drive that could be loose on the crank. BottomD
