CARB PROBLEM A JOHN DEERE
DALE HINTHORN
04-07-2006 18:53:24
I HAVE A JOHN DEERE A GAS MODEL . I AM HAVING A PROBLEM WITH IT FLOODING . I HAVE TRIED ADJUSTING THE FLOAT AND CHECKING FOR HOLES IN THE FLOAT. IT STILL FLOODS AND BLOWS BLACK SMOKE CHECKED AIR CLEANER. ITS CLEAR. WILL NOT ADJUST OUT WITH NEEDLES ON TOP OF CARB. IT HAS NEW KIT AND HAS BEEN CLEANED . STILL HAVE THE SAME PROBLEM . IS THERE A BREAK DOWN ON THE DLTX CARB OUT THERE THAT SHOWS A BREAK DOWN OF THIS CARB IS THERE ANYTHING THAT GOES ABOVE THE SPRING IN THE CENTER OF THE BOWL WHERE THE BIG NUT ATTACHES THE BOWL TO THE BODY OF THE CARB. I CANT SEEM TO GET THE HANG OF THESE CARB.
buckeye al
04-10-2006 15:09:32
 Re: CARB PROBLEM A JOHN DEERE in reply to DALE HINTHORN, 04-07-2006 18:53:24
Many times if the problem is float related, with the engine running turn the fuel off at the tank. If the float is the problem the engine is likely to straighten up & fly right after a few seconds.. That is, until the fuel bowl is empty & it runs out of fuel! It may however fly right just before it quits for lack of fuel! These are hints as to what is actually happening.
You did not mention the year of the tractor which is important! Let's assume all of the passageways and vents are clear and the float valve is indeed shutting off properly as they should be. After all, this carb's been "gone through", it just doesn't work right.
I suspect you have a late styled (SN after 584000) and it has a DLTX 71 or 72 carburetor on it. I'd verify proper assembly and operation of the choke!
On the choke lever under the little round metal cap that is held in place by the leaf spring, rotate the leaf spring off of the cap & remove the cap. Look to see if the pin on the choke lever (part pulled by the rod) and the pin in the choke shaft have passed each other.
With the engine not running, choke off, these pins should be held against each other under spring tension with the choke shaft pin in FRONT of the lever's horizontal pin. They should be held together and under spring tension all the time until the choke lever is pulled to the full choke position. Only then should they separate and then not by much! In the last bit of travel of the choke lever, the lever's pin should pull away from the choke shaft pin towards the rear of the tractor. (The choke shaft should stop rotating along with the lever only in the last small part of the lever's travel.)
I have replaced defective lever pins with 5/32 gas welding rod driven into and brazed in place in worn levers.
Good luck & post back with what you find.
Later.
John T
04-08-2006 06:49:12
Dale, I dont think its a nozzle problem causing the flooding. That bottom center spring holds the nozzle up in place when new, but once they age in it never falls out anyway. You say you have tried adjusting the float, I would want to know exactly if its working and at what float bowl level its shutting off the gas. To do that you could remove the bowls bottom drain cock plug and insert a fitting with a hose barb and use clear plastic tubing held high above the carb, turn her on and observe the level if and where she shuts the gas off. If the level rises above the bowl top and floods over you have a float or a needle n seat problem causing the flooding. Even without that method one can remove the air inlet piping and look into the carbs bore and see if gas is entering and running out (float or needle n seat problem). Also to insure theres no inlet air restrictions in the inlett piping or cleaner etc., remove it n if no gas runs out see if she will run that way?? n if so there must be a restriction in the piping or air cleaner screen mesh etc causing the rich running.
If the float has no leaks then gum n varnish or crud may be preventing the needle from rising n seating into the seat to shut the gas off. I would turn the gas off at the sediment bowl in the meantime so gas dont flood over and fill the crankcase and check the oil if gas has already entered the crankcase.
Sounds like a needle n seat problem for now at least assuming the air cleaner n piping n screen mesh are NOT restricted???
John T
Dave NE IA
04-07-2006 19:42:36
There is a nozzle up in there, will look like a high powered rifle shell. Usualy a little problem as they seldom fall out, but can be taken out easy with a little knowledge. Do no pry it out. There are more posts on this site than you can shake a stick at. Post back if it has a nozzle. Robertscarbreatorrepair web site has a break down. Dave NE IA
