2510 Transmission Problem
Sam w
04-07-2006 17:05:23
I have a 2510 gas with a synchro Tansmission. A neighbor borrowed it, came back with out reverse. Removed the top cover and found thproblem with the reverse synchronizer. I split the tractor and I am trying to get the top shaft out. The manual says it will come out, I can't get it out. Is there A trick that the book left out? I would appreciate any info.
Sam w
04-09-2006 17:05:24
 Re: 2510 Transmission Problem in reply to Sam w, 04-07-2006 17:05:23
Thanks for the info,finally got it out.
HTR
04-08-2006 14:55:23
After you remove the rockshaft housing, and the transmission pump, you have to drive the rear bearing cup back. Then raise the front of the shaft assembly, and lift it out of the top of the case. Hope I am not telling you something you already know.
bernie in VA
04-08-2006 13:07:22
 Re: 2510 Transmission Problem - Hey Glen in Texas in reply to Sam w, 04-07-2006 17:05:23
How much do you want for the 2510 manual?
Glen in TX
04-08-2006 09:52:01
I thought that shaft came out the front? That's what the JD manual I have says. I didn't look at the I&T one. The shifter shafts have to come out too to let the shifter assembly swing up and out I think before that shaft will slide out front. I might make someone a good deal on some JD 2510 manuals if needed.
