720 crank and taper lock
Chatermb
04-07-2006 13:16:12
I have a 720 diesel in pieces. The flywheel is loose on the crankshaft. The splines on the cranks are worn somewhat from the loose flywheel. A taper lock is being shipped to me. As I have never installed one of these I don't know much about it. I would like to re-install the crankshaft, pistons, rods, head and injection system this weekend as field work will begin shortly. My question is, is any machining that needs to be done to install the taper lock done on the flywheel or is there machining needed on the crankshaft as well? There is very little point in putting the crank in, only to take it out when the taper lock shows up.
Thanks for your help on this question.
DSK
04-07-2006 19:41:20
 Re: 720 crank and taper lock in reply to Chatermb, 04-07-2006 13:16:12
Make sure you adjust crank end play before you tighten the flywheel up with the big nut. Proper end play is .005-.010. When you install tapered sleeve on crank, insert a .005 feeler gauge between sleeve and the flywheel spacer and drive sleeve up snug. Make sure you have clutch engaged and pulley blocked tightly to the left (towards tractor) before you install sleeve. A 4 ft. pipewrench works well for tightening the big nut, you can get on it pretty good as nut needs to be tight enough to compress sleeve onto the crank. When you put the tractor together don't install the crankcase cover (or starting engine) until you have installed the flywheel, it works best to block the crankshaft lefthand throw with a piece of 4x4 hardwood against the back crankcase wall when tightening the large nut. I installed a taperlock on my 70 gas last fall and the only problem I had was the flywheel cover didn't fit up to the main case, I had to have the cover widened 5/8" to make it fit. Some taper-locks require this and others I've seen do not. At any rate, they work very well.
mjbrown
04-07-2006 15:42:19
I put one on my 730 after stripping the splines out of the original flywheel while raking hay. Mine was an after market maybe M&W but no machining was needed. The cone fits on the crank splines and the flywheel goes on the cone and a big square nut draws the wheel tight onto the cone and squeezes it tight on the crank. You have to put the cone on in time I think and there is a pin that engages the slinger gear I think. If your crank splines are peened over you may want to clean them up with a file.
