Grass seeder settings for a model B drill needed
Randy Varilek
04-06-2006 21:58:27
We are planning to put in alfalfa with our model b drill and i need to know were to set the grass seeder to get 15 to 17 lbs of seed per acre. the indicator goes from 1 to 16 but i know this can't be pounds because different types of seed require different setings. anyone have a manual that tells approximately where to set this thing? Thanks in advance.
spud
04-07-2006 00:44:15
 Re: Grass seeder settings for a model B drill need in reply to Randy Varilek, 04-06-2006 21:58:27
My experience with grass seeders have told me that it is best mark off a given distance, catch the seed from two or three seed tubes, calibrate the distance acreage and calibrate the seeder from their. With theprice of that seed a guy doesn't want to over
do the rate. It just seems that most seeders are not accurate with the application chart. Good luck.
