1518 batwing questions- help?
mud
04-06-2006 19:48:30
What does this mower weigh?
Is the gearbox speed 1,000 RPM?
What does an average one bring in your area?
Thanks -mud
Jason Z in MO
04-06-2006 20:39:47
 Re: 1518 batwing questions- help? in reply to mud, 04-06-2006 19:48:30
I have a 1518 and it's 1000 RPM. I would have to look in the book for the weight but for some reason 3000 lb jumps in my mind. That seems heavy... but thats my first guess. I can check the manual in the shop tomorrow.
Mine has been a very good machine but I would check the wing hinges. Two years ago I found the 1" hinge pins had twisted in half! I had one wing held on by only one hinge! Each wing is held onto the main deck with 3 hinge points. Look very closely between each set and make sure the pins aren't twisted in half.
Deere never made provisions to grease these hinges so after time they rusted tight. Checking the specs on the part numbers, Deere reduced the pin diameter for the replacements.
After HOURS of work I got the old pins out and replaced them. But not before I installs grease fittings. Now I can grease the original hinges and the new ones. The wings operate very smoothly now.
mud
04-06-2006 20:49:38
 Re: 1518 batwing questions- help? in reply to Jason Z in MO, 04-06-2006 20:39:47
Thanks - Thats a big help to know.
