Can an JD 60 pull
MattG
04-06-2006 17:42:44
Can a JD 60 pull an 12" Disc or would that be to big for it?
Thanks.
Matt
MattG
04-07-2006 15:44:25
 Re: Can an JD 60 pull in reply to MattG, 04-06-2006 17:42:44
Thanks for all your answers. I will start looking for an 8 or 10" disk. There is an consignment auction this weekend with an 12" disc and I didnt know if an 60 could do it. But now I do.
Thanks.
jturbo
04-07-2006 14:45:36
Can it pull it? Yes but not at the depth or speed you want it to operate...a twelve foot disk with any weight and sharp disks in plowed ground will give a 70D all it wants much less a 60. Do you tractor a favor and get a better matched disk for all conditions...I"d recommend a wheeled 10ft JD disk. Just my opinion.
Bobl1958
04-07-2006 11:07:44
I have a strong 60 but would hate to tackle a 12' disc. Probably would pull it in light ground, and pretty shallow, but if you tried to put it in the ground it would be pretty hard on the tractor. A 10' disc would be much better. Bob
jd2830
04-07-2006 05:37:35
MY 530 PULLS A 12 FOOT DISC BUT IT KNOWS ITS THERE PULLS IT IN 2ND AND 3RD
RFH
04-07-2006 04:37:53
We pull a 12' disk with a 720 diesel in 3rd gear. It works the tractor pretty hard first pass in freshly plowed ground. I know a 60 couldn't do it, at least with our disk and where we live.
960
04-06-2006 21:04:46
In the late 60's as a youth used a 12 foot RW wheels up with the JD 60 had power block with duals on plowed ground, third gear in fine sandy loam. It was not the best cutting disk as it was too light. Still remember the red muffler at night when I was suppose to be home doing home work. Today its a 4650 mfwd with a 24 foot soil finisher both work much better.
jdman(MO)
04-06-2006 20:45:55
I have a 14 foot AW JD and a 10 foot IHC and they are a load for a 70 and 2510 in plowed ground. I suggest a 8 foot, as that is what I wish I had. The other option is not to disk as deep as it will go. Russ
farmerboy
04-06-2006 19:48:31
third party image
My 1955 60 worked itself to death in front of an 8 foot RWA Deere and 2 harrow sections on moldboard plowed hilly clay ground last spring. It did OK with just the disk. If you were scratching the top of the ground, it might do ok but then you're not doing any good.
Here's a pic of it cultivating. It did that great.
CLW
04-06-2006 18:14:56
Matt, I can't say from experince but I have a video taken when the 30 series came out. It has a 630 pulling a 13 ft. disk. I would say to be safe you may want to go a little smaller. Maybe no larger than a 10 as the 630 is about 20% more power than a 60 if I recall correctly.
CLW
buickanddeere
04-06-2006 18:06:45
In 6th gear if on the road with the disk up.
