Fuel Filter cahnge on JD 2020
MWHall
04-06-2006 10:46:35
Any tips on changing a JD 2020 diesel fuel filter? I have the glass bowl on bottom with drain screw and a bleeder screw on top. Uses a ring type 31866 filter from wix. I have changed fuel filters like this on MF 175 but never on this JD
Thanks
Glen in TX
04-06-2006 21:37:35
 Re: Fuel Filter cahnge on JD 2020 in reply to MWHall, 04-06-2006 10:46:35
Those ones with glass bowls were designed by Stanadyne and used on many brands of tractors and engines. We use to get JD or Baldwin or Case filters for them and they were all the same and interchanged with no problems. Many of the other brands won't come with all the right gaskets and o-rings you need so usually best to just get them at JD dealer and price might even be less or the same. Just don't tighten the glass bowls too tight.
