JD 3010 Row Crop Transmission
Curt Cooke
04-06-2006 07:58:47
A fellow left me a 3010 to repair. Claims that there are several gears that it won't shift into. Said something about worn out parts (bearings) in the transmission. I'm a Moline/Farmall guy and am seeking counsel. What and where is the problem likely to be?
Thanks for your help.
msb
04-06-2006 08:11:31
 Re: JD 3010 Row Crop Transmission in reply to Curt Cooke, 04-06-2006 07:58:47
First place to start is with the shifter adjustment.Sometimes the adjustment can get so out of adjustment that it is possible to overshift the transmission making one thing the gears are gone.
The next place is the top shaft.It would be helpful to know how many hours are on the tractor.You nay have to go clear to the bottom shaft to fix it if the bearings are really shot.
Is there a chance the tractor was towed without first being placed in the "TOW" position?(even a short distance) You might want to ask the owner that question first.
Curt Cooke
04-06-2006 12:29:23
 Re: JD 3010 Row Crop Transmission in reply to msb, 04-06-2006 08:11:31
I doubt if the owner knows anything about the towing. He bought it at an auction sale. Another thing. Is this a 24 volt electrical system?
msb
04-06-2006 17:31:15
 Re: JD 3010 Row Crop Transmission in reply to Curt Cooke, 04-06-2006 12:29:23
If its a a diesel then it is a 24 volt system unless it has been converted over to 12 volt.
You will soon know if it has been towed without the shift lever set in the tow position,when you take the top off the transmission.Towing welds the gears to the top shaft from spinnging too fast without any lubrication.It turns the gears a bluish color.Hopefully that is not the problem.Probably cost more to fix than the tractor is worth if that is the case.
Bob
04-06-2006 08:06:16
Check the synchronizers and shift fork on the transmission's top shaft.
