49 JD A oil cap cap will not seat and leaks!!!
james in tx
04-05-2006 18:20:53
I'm working on a 49' styled A and when I removed the oil cap, the bolt became loose and will not go back in. tried to remove the oil pump but it will not move. My JD buddies are stumpt. The oil cap will not seat fully. Need some help.
430WLPG
04-06-2006 16:04:53
 Re: 49 JD A oil cap cap will not seat and leaks!!! in reply to james in tx, 04-05-2006 18:20:53
The stud may have broken loose from the filter head,and that is a hard job to swap it out,because of all the plumbing in side, but it can be done.Removing the oil pump won't help much,it would have to have all the oil lines unhooked for it to come out.
sds46a
04-06-2006 07:35:10
CalJim,
Make sure all of the old gasket is out. Sometimes you need to use a pick to get it all out.
Doug
CalJim
04-05-2006 22:28:13
Hello, When you say "oil cap" I assume you are talking about the oil filter cap under the tractor. Check the threads on the stud (bolt) that came out, they may be different at each end. You will not get the oil pump out without pounding out the oil filter body from underneath, I don't think you need to do that, just work on getting the stud back in and the cap should seat ok. CalJim
