How much can you turn crank rod journals on '51 B?
Kurt_JDB
04-05-2006 16:27:23
My crankshaft has damaged splines on the clutch side. I located a crank with good splines, but the rods have been off of it for many years and the rod journals are pretty rusty. I have babbited rods in my tractor. How much can I turn this rusty crankshaft? How much adjustment is there in babbited rods?
Thanks.
Kurt
Maark
04-06-2006 11:18:40
 Re: How much can you turn crank rod journals on '5 in reply to Kurt_JDB, 04-05-2006 16:27:23
Babbitted rods have about .125 shim pack, or about 1/8th inch.
Kurt_JDB
04-06-2006 12:48:43
 Re: How much can you turn crank rod journals on '5 in reply to Maark, 04-06-2006 11:18:40
Maark,
Thankyou for the reply. Am I to understand that It is usual practice to turn a crank and then remove shims until the rod is properly adjusted on a crank with babbited bearings? Would the rods also need to be bored in some way so that the curve of the babbit material matched the journal?
Thanks for the info, this is the first time I have worked on a machine with babbited bearings.
Kurt
CalJim
04-05-2006 22:09:09
Hello, You can also get the splines repaired, Mike Williams in Iowa.
wddave
04-05-2006 18:21:16
There are .020 under insert bearings available. Machine shop can rework the rods to accept the inserts.
