Help Identify the year of my A
MDM
04-05-2006 09:43:36
I need help to identify the year of my A, the serial tag is worn enough and torn that I cannot read it, are there any casting #"s that may help narrow iit down. It is a styled A with pressed steel frame and a battery box seat, 2 stick transmission. thanks
CLW
04-05-2006 14:36:34
 Re: Help Identify the year of my A in reply to MDM, 04-05-2006 09:43:36
Your A is somewhere between 584000 built 3-31-1947 and 647999 which was built as an early 50 model. CLW
Frank in WV
04-05-2006 11:40:22
MDM,
Your A should be somwhere between a 1947 and 1950. Pressed steel frame came out in 47 and two stick shifter was changed over to single stick around 1950. Do not have the exact serial number years handy. You also should have a round axle versus a square axle. Check out the serial # listing on this site, my guess is you are somewhere between 578000 and 650000 for a serial #. Did you try rubbing a lead pencil over the tag to try and darken the serial # to seee if it was readable. Check your block casting number and the parts book, early styled A's did not have a top center nut if I remember correctly.
Best of luck.
