Carb. Problem
BottomD
04-05-2006 08:54:16
HI I'm on the same B the carb is a DLTX 34. The extearer threads that hold the bowl on seem to be worn I got a nut from the junk yard and the threads seem to look real good.I can push the nut about half way up the threads before I even turn the nut.Do different carbs have different size threads? If not is there any way to fix this? Thanks for your input.BottomB
Duane Larson
04-05-2006 14:04:38
 Re: Carb. Problem in reply to BottomD, 04-05-2006 08:54:16
BottomD,
I agree that a new nut with new threads may solve your problem. Check with www.robertscarbrepair.com you can order on line there.
An alternative way to those presented is to cut off your threads JUST above the threaded part, square up (I use a lathe), cut the threaded part of a Champion W18 plug off, bevel the bottom end of the plug threads (after removing the ground strap) and the carb bottom, carefully line up, and braze the plug threads to the carb neck. I have several jigs built to make the process easier, and have done a bunch this way without problems. Both the plug and old neck have 7/8"-18 threads.
F-I-T
04-05-2006 13:13:10
A good way to fix it is to use a trepan cutter, sometimes called a hollow mill, with a pilot or arbor to guide straight down into the bore where the nozzle sits. Plunge down over the end, leaving a smooth surface on the cast. Then braze/sweat a custom made soft steel bushing over that, then re-thread. That's how I have fixed mine. Good as new, but lots of time in the shop.
Frank
Mike M
04-05-2006 09:27:21
Try getting a BRAND new nut from Deere it may fit tighter.
Dave NE IA
04-05-2006 09:02:16
You are looking at about 50 -70 dollars to redo the stem. Roberts or Burrey will do you a good job. I have a rethreader, but you need material to remove, not your case as you described.Dave NE IA
