Fan shroud, 43 styled G
crazy8
04-04-2006 16:07:19
I am working on a g and need to replace the fan shroud . Do I have to remove the radiator to do this. Q 2 Can the fan spring be compressed to squeeze the shroud in? Thanks
JLG
04-05-2006 14:41:28
 Re: Fan shroud, 43 styled G in reply to crazy8, 04-04-2006 16:07:19
I put one in my 1950 "G". It"s been a little while now but I know I left the radiator in place. I had to loosen the fan shaft at the front and where it goes in the govenor. Also removed the front grills, hood, and probably most of the parts mentioned below. I was really tempted to just cut the shroud in half, stick in in and tack weld it back together. But these tractors are so simple it really doesn"t take too long to unbolt everything thats in your way and put it all back.
Easydoesit
04-05-2006 14:22:28
My feeble memory says that you have to remove the hood and front sheet metal, loosen radiator hoses top and bottom, remove exhaust pipe to stack, pull two radiator bolts, remove air filter to carb hose, pull radiator foreward and up, slip shroud in. Maybe I forgot something or maybe you will come back and say that you did it the easy way...Easy
