Mike, I will provide you the "short answer" to get you started and let the "Carb Experts" provide the details. Of course, you need good plugs and a good hot blue spark and fresh clean gas and a well tuned ignition for a good idle also. Its likely an idle circuit is plugged problem, see below. 1) First thing I would try is see if any adjustment of the carb top idle needle cures the problem?? I set mine initially at around 1.5 to 2 turns out then adjust from there at a slow idle. 2) Next I would insure the governor throttle rod adjustment to the carb is set right. If the rod is removed from the carb top to the governor and BOTH the carb and hand throtle set wide open, the length ought to be adjusted so the rod is about 1/2 hole short of dropping down into the carb. When installing WATCH OUT that theres no cotter key or wires binding up free operation in the rod and carb top. Also see if the vertical idle stop spring is in place and at idle the throttle ought to be just bumping up against that stop spring for best operation. 3) Next to see if its a carb or governor issue I would remove the governor linkage and see if its possible to manually hold the carb to a position to yield a slow sweet smooth idle or is she still acts the same. 4) Next to see if its a vacuum leak thats causing the idle problem A COMMON PROBLEM, I would use an unlit propane torch or Carb Cleaner or WD 40 etc and at slow idle spray it around the manifold base and the carb and ESPECIALLY the carbs throttle shaft bushings (common vacuum leak place) and if she speeds up or smoothes out YOU FOUND THE PLACE SHES LEAKING VACUUM n sucking in air which leans the mixture causing poor idle. FINALLY if she passes alllll l those tests and adjustment dont help and she surges n hunts up n down up n down via governor action at idle, I SUSPECT THERES A CLOG OR RESTRICTION IN THE CARBS INTERNAL IDLE CIRCUITS. If thats the case, cleaning or gumout or soaking or boiling may not help at all and whats required is to use gentle heat (small torch tip stopping IMMEDIATELY when the off green funny color appears) to remove each n every brass drill plug then use the extra long No 40 and No 53 aircraft drill bits (right bits in correct holes only, use wire in smaller holes) available form Roberts Carb and light drill n clean out alllll llll the idle passages. See http://www.robertscarbrepair.com/tip1.htm It takes a good carb with alllll clean idle passages with no vacuum leaks (good throtle shaft bushings) and the throttle shaft bushings installed deep into the bore correctly and a throttle plates thats concentric and fills the bore and a good hot ignition to get a good slow sweet idle. If adjustments dont help and its NOT a vacuum leak or worn throttle shaft bushings and the governor linkage is correct and she still surges up n down n hunts up n down, IDLE CIRCUITS PLUGGED UP. However, if youre in there anyway I would pull the nozzle and clean it also and install a rebuild kit with new bushings. Hope this helps, let us know, best wishes n God Bless John T
